They all (4) run on 50A, but additional loads such as the microwave will be powered through the inverter(s) pulling on the batteries. If the batteries are low and the inverter/chargers are charging them at the higher rates (the inverters not adjusted for a lower amp charge rate) it has been my experience that the total load will then often pop the pole breaker outside.
