Fully Automatic Shot Gun Video
I don't know if I got this link from POG a few months ago or if it came to my inbox from elsewhere but this is a must see whether you have a gun or not. Amazing no matter who you are. Check this out:
http://www.youtube.com/watch?v=p4ebtj1jR7c
Drive Off versus Confrontation
Hi Jon,
I agree with you on the Drive off from the scene approach, but inline with my previous comment about the Situation and situational awareness is the key to all of it I suppose.. can you get out of the situation by starting up the bus and do you have the time required to get it in gear and get gone...??
if you can thats great, if not .. Oh well
Thats the Fifty Dollar Question that hopefully none of us really want to know the answer to... and I hope it does'nt happen to anyone, but being Legally armed is the Best Advantage when weighing out the options.
Preventive maintenance is a beautiful thing in certain cases. as the old saying goes an ounce of prevention is worth a pound of cure.
I like the old Boy Scout moto also always be Prepared ! Expect the worst and hope for the best .. Dry Matches and Clean Socks .. ya-Hoo has taken me pretty far in life now.
In regards to bus weight if my bus being 40 feet long is basically a 1000 lb per foot then I would guess your bus to be between 45-46 k .. i think you had mentioned in your previous line it was 46K though...
Ok on the CAT scales, I will have each axle read for the weight so that I can ensure I am with the proper tire inflation pressures...
the previous owner stated that he had been running 100 P.S.I. in all the tires and it has all Brand new Rubber ( Firestones ) on the Drive and Tag Axles as well the Steers are at 95% Michelin's ...
Is there a Chart for Recommended Tire Inflation pressures to Weight Ratios on the POG here ? I will appreciate your additional comments.
Have you ever run Dry Air Nitrogen in your tires ?
