Originally Posted by
travelite
RussWhite, Thank you for your generous offer. I'll send you a PM.
Tuga, I'm beginning to understand. It seems that one end is factory glued and the other end is cut to length, glued, and clamped. It also appears that the ends are positioned at the bottom of the slide. This is where it gets fuzzy for me. How do you achieve a weather tight seal where the clamp is placed? How big is the clamp? Do you position the clamp adjacent to the slide or does it get tucked in somewhere? Thanks so much for your help.
