Originally Posted by
Jon Wehrenberg
I'm with Jack. I not only want to minimize weight, but I want that weight as low as possible. I don't know how much driving of coaches you have done Donnie, but up here in the area around the Smokies the roads wind and curve, and while you may not think so, sticking 400 pounds of roof airs on a coach as opposed to the weight of the Cruise Airs almost below the centerline of the axle will have a profound impact on an air bag suspension and how it controls the coach. That 400 pounds 12 feet above the road, and 10 feet above the air bags is a huge lever arm that forces the air bags (and the ride height valves) to have considerably higher internal pressures to resist leaning in a curve. Further, if the curves are spaced such that the coach ride height system gets behind the "curve" you have the leans counter to the way the coach would be expected to lean through the curve. The only difference is the frequency and spacing of the road curves will have a different effect on slow acting or fast acting ride height vales, but they will both be affected by that high mounted weight.
I'm a pilot also.
As to the assertion the Cruise airs are troublesome I have to disagree. Admittedly I don't have Cruise Airs Dometic has dumbed down to equal the quality of roof airs, but unless Dometic has completely redesigned them my 20 years experience with them has been very good. The biggest problem I see are technicians that do not clearly understand the operating pressure charts and as a result under or over charge the units. My first coach was 17 years old when I replaced all three condenser units, and I did that because one of the compressors locked up, and when I opened up the unit I saw how driving the coach for years in the snow belt during the winter had compromised the coils. I have four in the present coach which has a 14 year old chassis and so far I have not done a thing to them except clean the coiuld on occasion.
