60 Series Fan Install Part 2
		Attachment 5201
Install magnetic ring with 3 bolts
Attachment 5202
the piece on the bottom is the old part
the top piece is the new part
Attachment 5203
Put heat sink on with 3 nuts
Attachment 5204
Ready to go into Bus
Attachment 5205
I removed the pipe from the charge air cooler and pushed it up as far as I could.  This gave me room to slide the assembly into place.
Then I put the mounting plate onto the assembly.  This is where taking pictures ahead of time paid off.  Made it a lot easier to get things back in the same place.
The hole that is in the back angled part of the mount is where I used a large cable tie to fasten the wire from the clutch assembly.  The change in design of the clutch prevents running it in the sane way that the original wire was run.
		60 Series fan install part 3
		Attachment 5206
Pulley attached
Attachment 5207
cable tie for holding wire
Attachment 5208
fan running, no weird growling noice
SUCCESS !!
I used blue Loctite on all bolts and nuts
I suspect that the first indication that something was going bad with this part was a few months back when I started throwing the 3 belts that go to the gear box from the engine.  Whenever the fan kicked in the whole fan mount would jump around.  I raised the air pressure going to the air bags and that helped, but the whole fan assembly seem to still jerk to much when the fan kicked in.
Then I started hearing the growling noise.
Now with the new part, when the fan kicks in, it is MUCH smoother, and does not jerk when the fan kicks in.
		Article: Series 60 Fan Clutch by Andre Ducote
