Roger,
Here's my post with the part numbers: http://forum.prevostownersgroup.com/...nsors-For-Sale
Roger,
Here's a link to DDEC II codes. They match with my DDEC II troubleshooting manual (you can find them on ebay for about $50, worth every penny if you are tracking down a problem), with these exceptions:
Code 53 missing - EEPROM failure Affecting code logging
Code 47/48 - Mislabled - should be 47 Fuel Pressure Sensor Signal Voltage High and 48 Fuel Pressure Sensor Signal Voltage Low
http://library.motoralldata.com/tech...DDEC_II%29.htm
Truk - what kind of reader do you have?
Steve
Steve, you da man!:cool: I checked a minor historic code I've been saving and it matches your list. I have the 9000 Pro-Link and the manual does not show the codes in your post and refers to SAE codes starting at 072 and nothing matches.
I'll add this list to the Archives so we always have it on file.
Thanks much....
What card are you using in the Prolink? I have a manual for the DDEC II/III card that I could copy if you need it...
Seve
