Not Inverter Repair - Just Understanding Mine...??
Viv's 88 Le Mirage XL Inverter...
Inverter that scares me...
I did touch it and I know I've messed it up...Lights won't come on even tho' the coach is still plugged into my 50 amp. outlet...
See I was afraid of that Inverter from the very beginning...
When I started the bus real cold air started blowing and I tried to shut it off...all the heat/air controls were off on all three air conditoners thermostats but that cold air was still coming really strong...no matter what switch on the Inverter I turned off...and on...or left off...I forget all I did...but eventually that cold air got warm...Maybe if I'd left it alone the cold air would have just warmed up...but I didn't think that way...just tried to shut it off because all three ac/heat thermostats are off...and I was freezing...!!!
I need to understand why I can't touch that Inverter...or how I safely can..
I can send you a pic of the position of each switch if you could tell from that what I need to change back to where you had them...I turned so many I can't remember which ones I turned...
Beat me... go ahead...but now I bet I'll learn...!!!!!!! Oh I hate those Inverters...I just don't understand them...!!!!!! Everything else makes sense to me but them...Forgive me...
Warm Hugs Always Love Viv...
