Originally Posted by
Jon Wehrenberg
			The system check valves are doing their job, and the broken fitting was located so the valves could work.
However, the lines to the relay valve appear intact, but one of them had been laying against the driveshaft and it was a question of time before it would have failed. When that line let go it became another air escape point. If the remaining line was then severed you have a third air escape point.
I am surmising the relay valve is not one originally installed on your coach, but is dedicated to the aux braking system. Even at that it should have been secured to the coach in the same manner as the original equipment valves are and the fact that it is hanging and is a few driveshaft rotations away from being ripped off tells me its mounting was inadequate.
Should you have an air loss that is in a location where the safety valves will not stop the leak your braking system air pressure will drop and once it falls to around 40 or 50 PSI your emergency brakes are going to automatically apply. It can be said the installation was a good one because you were protected from a catastophic air loss, but if my interpretation of the picture is correct and your relay valve was hanging as shown and the air lines were rubbing against a spinning driveshaft as it appears you could very well have experienced brake lockup.
