which is something that happens every minute of every day
I spoke with both James @ Prevost Car in Dallas, and Dale my service advisor @ S & S.
Dale found out there are some dual purpose Barometric and Turbo Boost Sensors in some of our buss's and that may be the culprit, in causing the intermitant failed readings. He is checking into the actual unit on my bus to see if this is indeed the dual sensing unit, and then will continue diagnostics to determine the next step.
Will get back when I know more, which is something that happens every minute of every day. :D I thought I would say it before everybody else said it. ;)
It's ALL GOOD ! "Loc's favorite saying"
Gary S.
New Barometric Boost Sensor
OK, so how many of you know IF YOU have a Barometric Boost Sensor or not attached to your DD60 engine?
Apparently I didn't have one?????? S & S installed a NEW STYLE Barometric Boost Sensor and wired it in line with the Turbo Boost Circuit. I asked the service advisor where they put it, but he didn't have a clue? :(
They also Reprogrammed the ECM to Raise the Software Level and to Sense the New Style Pressure System. :eek:
3 days in the shop, and $ 8 Big Lewbucks later, and I am off again. :cool:
Gary S.
