I agree, there is no doubt each inverter manufacturer handles the job a little different.
With the Magnum's, after driving, the batteries are well charged and mine immediately goes to bulk, then absorbtion and float rather quickly. The entire process takes less than 1 hour, but I haven't kept exact time. Before I hook to shore after driving, I turn off the chargers and turn them back on later after all the power needs sort of get worked out. There's no hurry for the chargers, so I wait.
Cycles are the big question in battery life. How you use your bus determines the cycles based on your particular charge parameters. Here's a few numbers to think about using Lifeline's AGM data:
Expected Life Cycle - 5000
Discharge - Voltage - Life Cycle
50% - 12.20 - 1000
75% - 11.75 - 600
100% - 10.50 - 375
So in theory, if I am diligent about my new batteries discharge rate not exceeding 50% (12.2 volts), I can expect about 1000 cycles. I will use more cycles than the guy who uses 75% (11.75 volts) and gets 600 cycles, but will I reach the end of my battery life before he does?:confused: I will also use the generator more often and use more fuel, but using the gen more in my opinion is a good thing.
Now I throw my auto-start into the picture and with the Liberty Watch Dog default start voltage of 11.15, approximately 90% discharge, I now only have about 440 life cycles. Batteries are very expensive!:(
I'm sticking with 12.2 per Lifelines recommendation, manually controlled of course:mad:and hope it all works out.;)
