Equal Tire Balance vs Dyna Beads
I know several of the guys use the Equal product to balance their tires, and like I usually do, I wanted to check on other products that might be in the market now to do the same thing.
I found a product called Dyna Beads, which is mfged by Innovative Balancing. http://www.innovativebalancing.com/
This product looks to be exceptional in what it does, but AGAIN I HAVE NO personal experience with it. Has anyone used this product?
I sent an email request to the mfg. of Innovative Balancing and asked if his product was better than Equal and if so, why?
This was his response to me:
Hi Gary,
Have you seen our Fleet page?
Equal is very abrasive to your inner liner, and if there's any moisture on the inside, Equal will clump up and stop working. Equal is an old product, actually nothing more than a bunch of ground up plastic than has the consistency of sand, but the abrasiveness of emery. It was used for balancing, but is nowhere near the type of material that a good balancing material requires.
Our product is designed for balancing Fleet tires and other types of tires, but that's it's only purpose.
It is totally non-abrasive, moisture has absolutely no effect on it's balancing properties, it will not grind down inside your tires, and will not create rubber dust. We have had our product re-used from one set of steers to another, with over 400,000 miles so far, but we don't know how far it will go.
In the shop, you won't find out product dusty and messy to work with, nor hazardous to your employees. Our beads our 2mm in dia, come in a bag, and you can either pour them in, or put the whole bag in, but the entire operation is clean and neat. We don't require any special dry-air handling like Equal does, as moisture doesn't affect our product.
From a money standpoint, we don't require large purchases. We have customers with 2 trucks, we have customers with 100, and our product comes 12 to a case. If you need 1 case, you buy one case, if you need more, buy what your budget allows, we don't dictate minimums.
One other small thing, our product does not require special filtered valve cores.
We have a lot of very happy Fleet customers, if you need a reference, give Carol a call at the toll free number below.
Robert
Technical Support
Ceramic Tire Balancing
Tel-USA: 866-352-7251
Tel-Outside USA: 585-467-6028
www.dynabeads.com
I put this out there just FYI. No sales commissions or referrals, I hope just good information for our group??? :)
Gary S.
