When do I start the generator...
I have 6 - 8D AGM batteries connected in parallel in my coach. When I am dry camping and the Link System inside is set on amp hours when should I start the generator to recharge the batteries? The only accessories that run off of my inverter are refrigerator/freezer, TV, Aqua Hot, & lights. My basement ACs do not run off of the inverter.
Someone at POG II (I think that it was Peter vS) told me that each battery had 300 amp hours. Therefore, I assume that 1800 amp hours would be completely discharged. So would I then start the generator @ 600 amp hours of discharge if I wanted to not allow the batteries to go below 50%?
Also, what is the difference between a 4D and an 8D battery?:eek:
