Jon- Thanks. I really wish I had captured some of the old coolant to see just how bad off it was before it all dumpted into the oil pan. Another reaosn to do things yourself. I could have done it myself. I should have done it myself. About 10 gallons out of what, 15 total (if it's not mixed with the Aqua Hot and Dan at Phoenix Royal confirmed mine is not mixed)......they got about 10 gallons out. I could try testing the coolant again when I change it again in a couple thousand miles for good measure. I'd have cobbled up test results I guess though..
By the way, this engine is not the one that blew up. It was the Angola engine. And I didn't put a new one or factory refurbished one in, just a used one. I belive it was defective wrist pins in the early series 60 (1994 chassis) that got that engine and not neglect of maintainence but having been kicked in the balls once I should really be more diligent so I don't suffer needlessly again. I printed out your maintaince sheet that is on here and filled it out and taped it to the back of one of the overhead drivers cabinets. Got a new air filter and fuel filer today, changed the generator oil out at 85 hours and put a new fule filter on it also. I got most of the stuff on your check list "checked" except for a few things. You going to Maine so you can help me fix the rest ? he,he
Going to try to hit up a Motosat dealer in Canton Ohio tommorow and get the sattalite straignted out. Place is called
www.CloudCasters.com Anybody ever used them ?
