This thread has about seen its day, however I think that it raised awareness of the importance of maintaining ones cooling system. I have my doubts whether or not the coolant needs be changed at regular intervals, say two years, or longer with the extended life coolant. I think it is common knowledge that Glycol does not wear out, what wears out are the additives to protect the engine, the organic compounds have a slower "burn" rate than the inorganic. I did a fair amount of research on this topic, and while I certainly claim to be no expert, it is apparent that if the proper ratio of SCA's are maintained, the coolant is still good. Looks to me like the additives in extended life coolant cannot be replaced by adding additional organic things...maybe they make it but it is certainly not marketed openly. I am positive that when adding additional SCA's cannot bring the fluid into tolerances, it is time for a change. The use of automotive antifreeze is probably not wise, however if it meets the 4985 spec, it looks to me like it is certainly ok in a pinch, provided that one adds the SCA's. My best guess is that there is a point where additional SCA's do not work, the coolant as we know it, is worn out and time for a change; that may well be two years or five years and in rare cases ten years!
John
