2 Attachment(s)
Here is the replacement. A block of wood and some W-D and presto.
Attachment 4608
Attachment 4609
I have found hub seal on this corner leaking. Good grief. It started just sitting here because I am sure it was not on the last trip. I had a drive hub leaking when we got it but this is the first tag/steer hub that has failed for us.
Joe, thank you. Your pictures are appreciated.
Great pictures Joe, and nice to have a narrative to go along.
Looks like you're keeping plenty busy!
1 Attachment(s)
Here r some changes ive uncovered on a 2012, a chassis I'm currently under but not normally with a chassis so young.
Attachment 14574
I was going to try to trick someone with this picture but I'll cut to the chase.
It looks like an upper a arm bushing and it very easily could be, but it isint.
It is a pic of a radius rod bushing on the tag axle on this 2012 and that Bush looks like the bushes they used in the upper arms when ifs first came out, also another part that has gone through 3 or 4 improvement or changes between then and now. I know of 4 different upper arms over the run with ifs.
The drive axle still sports the radius rods with the older style rubber donuts.
Lewpop lives on forever.
