Jon I am now getting ready to head over to the bus and do these test,
I believe that on the isolator there are 3 connections, one is "Main" One is "Alt". and one is "Aux" I get the lower reading off the "Main" which I believe to be the Chassis Battery. It is my plan to disconnect the "Alt" cable and the "main" cable and connect the 2 together. then go through the process of testing and running the Genset or even the shore power I guess. I also plan on turning off the shore, the 12/24 the house and the inverter power before disconnect and connections are made. i will also test the lines before turning any wrenches
