Jims........As I mentioned to Hector Jim E's model coach has what I call accumulator tanks plumbed directly to each air bag apparently to increase the volume of air available to each air bag. When you drain them, you drain the air bag also.
The tanks that have nothing to do with the suspension system are the wet, primary, secondary and aux air tanks and as I mentioned they are all ahead of the five port Norgren that blocks air flow out of the air bags.
I suspected the 3 port because I though Jim E said the tank drains were replaced.
Jim C, your coach does not have the tanks whose drains were creating the problem.
