Ken went out to the hangar today and removed the burner unit, and brought it to my house (I'm still working).
At a quick glance, without taking the unit apart further, there appears to be some leakage on the input banjo tube perhaps near the base where it is screwed in. In looking at this is obvious that this unit had been upgraded prior. It is a 10 bar pump.
BUT, it seems that a couple of things were done wrong:
1. The gaskets at the bottom to seal around the in/out pipes are keyed. There is a left and right gasket, and it appears that the input side is either backwards, or the wrong one. It got pretty mangled, and was letting in air. This would cause the white smoke I was seeing.
2. The banjo washers don't appear to be correct. They are much bigger then the new washers which came with my upgrade kit. The upgrade washers are very very thin, while the two washers on the banjo bolts in the unit right now, are different sizes, and much larger than what I purchased.
I'm thinking that is where the real issue is right now.
