Ok. When I saw yours blown apart and u mentioned the o rings. U were talking about the 2 little orings on the manifold. Ten fer.
If anyone is interested in old removed norgrens for whatever reason I have some u can have. As many as u want.
My New Norgren 5 stack just arrived. Once I have all the air components in my possession I can start the swap outs.
http://forum.prevostownersgroup.com/...id=17299&stc=1
I also received my new door strap. This broke when i was stuck on the side of the 40 Fwy back in September. Prevost Used Rivets, I am going to use stainless screws and nuts.
http://forum.prevostownersgroup.com/...id=17300&stc=1
http://forum.prevostownersgroup.com/...id=17301&stc=1
Mike:
If you don't mind me asking: what did the 5 port cost you?
Chuck
You mean the 5 Stack in the Picture? That 5 valve bank was $261.14 direct from Norgren/IMI. I think I am going to replace the connectors also, some of mine have corrosion.
This sounds like the problem I am having. Will replacing the O rings solve the problem?
you can replace the 5 stack no problem, it's not that tough, It might be better to confirm your issue though first?
Agreed on confirming the issue. If you can confirm and isolate the bad valve on the 5 stack, the O-rings will come with the replacement valve and it takes no time to put in the valve on the stack.
Replacing the whole stack or just the one that is leaking is not a problem for me. I will get the part# and contact Norgen as you mentioned. Thanks guys.
I ordered mine from Prevost
