Dale, I'll to dig them out of the box to see.
Dale, I use the SmarTire monitoring which has the sensors inside the tire. I really like the system, however when I went online to their website, it says that they no longer offer that system for motorhomes. It seems like they only do trucks and buses.
Cam Colon
Hello,
I am assuming that I would have metal air gauges on my 98 45 footer with 315 on the bus. Am I correct on thinking this?
Thanks
I'm not following your question. You will have metal valve stems.
Hi Gil,
I am looking at purchasing the TST 507 tire monitoring system with flow through valves. With these they require metal valve stems. On my toad, I need to check I can't use the flow through valves as it probably has rubber stems. But I can use with the system the NON flow though monitors. I was just confirming that I would have the metal stems as I like the idea of being able to add air easily.
Thanks
I'm not the norm when it comes to TPMS sensors. I won't use air-through sensors. I use the commercial truck version of the 507 sensors. These don't support air-through and don't have replaceable batteries.
Your coach valve stems are definitely metal, most likely chromed brass.
