John, wouldn't they "Prevost" change the primary and secondary filters with a level 3 service anyway? I have been trying to get a list from Prevost or any one that shows exactly what is done with a level1,2,and three service Do you have one?
Got the following list of leval 1,2 and 3 service from Keith Wilson at the Nashville service center.
LEVEL 1 ENGINE SERVICE:
ENGINE SERVICE:
Engine Service (Oil Change) WT: Quarts: Reservoir:
Change Engine Oil Filters ( Yes / No )
Change Fuel Filters ( Yes / Not required )
Change Engine Coolant Level: Gallons:
Check Coolant: PH level: Freeze point:
INSPECTION SERVICE
Inspect Engine air filter ( Pass / Fail )
Inspect Engine main belts ( Pass / Fail )
Inspect Wheel seals ( Pass / Fail )
Grease drive line U-joints ( Yes / No )
Grease King pins ( Yes / No )
Grease Tie rod ends ( Yes / No )
¬_________________________________________________ ______________
LEVEL 2 ENGINE / LUBE SERVICE
ENGINE SERVICE:
Change Engine Oil: WT: Quarts: Reservoir:
Change Engine Oil Filter(s): Yes / No
Replace Fuel Filter(s): Yes / No / Not Required
Inspect Engine Air Filter: Pass / Fail
Inspect Main Engine Belts: Pass / Fail
FLUID LEVELS:
Check Differential Fluid Level: Quarts: Type:
Check Engine Coolant Level: Gallons:
Check Coolant: PH Level: Freeze Point:
Change Coolant Filter: Yes / No
Check Power Steering Fluid Level: Quarts: Type:
Check Fan Gear Box Fluid Level: Quarts: Type:
LUBE SERVICE:
Grease Front Axle King Pins: Yes / No
Grease ISS A-Arm Ball Joints: Yes / No
Grease Steering Linkage: Yes / No
Grease Brake Components As Required: Yes / No
Grease Tag Axle Lifting Rod: Yes / No
Grease Drive Line Ujoints: Yes / No
Inspect Wheel Seals (All Axles): Pass / Fail
Inspect Shocks For Leaks: Pass / Fail
__________________________________________________ _____________
LEVEL 3 FULL SERVICE / INSPECTION
ENGINE SERVICE:
Change Engine Oil Filter: Yes / No
Change Fuel Filter(s): Yes / No / Not Required
Inspect Engine Air Filter: Pass / Replaced
Inspect Main Engine Belts: Pass / Replaced
Inspect Mini Lobe Air Bags: Pass / Replaced
Check Belt Tension Air PSI: 50-55 PSI:
FLUID LEVELS:
Check Engine Coolant Level: Gallons: Freeze Point:
Change Coolant Filter: Yes / No PH Level: Additive:
Check Fan Gear Box Fluid: Quarts: Type:
Check Power Steering Fluid: Quarts: Type:
Check Differential Fluid: Quarts: Type:
Check Transmission Fluid: Quarts: Type:
LUBE SERVICE / INSPECTION
Inspect Wheels Seals (All Axles): Pass / Fail
Drain Air Tanks (Back to Front): Yes / No
Inspect For Oil Leaks: Pass / Fail
Check Hub Oil Levels: Quarts: Type:
Check Tire Air PSI: Fronts: Drives: Tags:
TRANSMISSION SERVICE
Change Transmission Fluid: Type: Quarts:
Change Transmission Filters: Yes / No
Inspect Out Put Shaft Seal: Pass / Fail
Inspect Transmission Hoses: Pass / Fail
We had stopped at a flying j in beaver utah for fuel 2years ago. Afterfueling at their rv island wedrove on. After our overnight stop, the next we could hardly get over loveland pass/eisenhour tunnel for loss of power and engine temp creep. At home, changed out filters,witnessed the same crud pictured earlier. New filters proved great results. When our 8v wants to show higber temps, the 1sr thing i check is the fuel filters twice now has proved this
