I don't get the heat issue. Turbo and exhaust is on the other side and the Webasto exhausts right out the bottom and back. The tow relay box is right next to it, so if heat were going to be an issue, I figure all those relays and electronic widgets in that box would be more likely to be effected than a tank with a simple valve and some HD plastic tubing.
