Diane,
Welcome aboard... You may want to also consider Lifeline AGM's, the Deka's I had in my Liberty only made it about 3 1/2 years and they were junk. They were properly maintained and charged according to spec.
Diane,
Pete, Yes you are right about things having a way of doubling in price, we've had that experience with the Navigator, I think maybe Dallas may be a better choice but as you say it's inconvenient. However a friend of ours was having trouble with his AC on a 2002 H3-45 and his bill was over 14K at Buddy Greggs and they kept it for about 6 weeks, I would have fainted !! and for that price that was just a fix nothing new other than parts, for that price I would have expected something new !! Look forward to meeting you also.
Diane
Thank you and we look forward to meeting you too.
Diane
Thanks for the great info..we have used them on some warranty work before and they were good. Larry will call Loc for some info. Hope to meet you in Kerrville. again, Thanks.. Diane
Yes, It sounds like it, thanks for the warm welcome, hope to see you in Kerrville.
Reagan, thanks for your words of wisdom !! We will NOT be using Birdland for sure, such a shame people are out there just waiting to screw you !! I pity all the owners of the Prevosts waiting for service there, they need to join the POG for the real scoop !! I guess the good ole days are long gone eh? !! Hope to see you in Kerrville.
Diane
Diane,
I want to add to Truk's advice. Your batteries are probably the most important thing on your coach because life sucks when they start acting up and your voltage can't be held without charging them often. They need proper care, and if given the right care and not abused 5 years of life is not unusual.
The bad part about batteries is if one goes bad you almost have to replace the entire set so it is important for you to understand your inverters and how they are programmed and to make sure the charging protocol is correct for your battery type. As to Deka vs Lifeline, AGM vs gel cell, etc. I would suggest you search the POG forum and read and understand all you can about batteries. I think the concensus here is Lifeline AGM provide good service for the dollar.
Thanks Jon.. I will certainly do that.
Rick...Many many thanks !!! I can't thank you enough it is awesome to have that inverter doing what its supposed to do.. I won't forget where those resets are I can tell you that. Again thank you so much. Will you be at the Kerrville Rally?
yes we will,if you have any other questions just call
