Hector,
Looks like a great building! I know you are anxious to get it finished. Post more pics soon.
Hector,
Mel, Nice Bus Barn you have there but it could use a coat of paint soon.
Well Jim K. I disagree with it needing paint. The primer color Hector has chosen to use on his new steel, goes extremely well with the exterior color scheme on his bus. :) You GO Hector !
However, I don't see it as being big enough for two? :confused: How are you going to work on my bus if it can't fit inside along yours? :eek:
Gary S.
Looks great Hector. All those skylights really brighten things up!
Gary,
Not to worry, always room for your coach. I will move the Country Coach with the enhanced custom designed Lexan rock shield over to one side. Even though you do not have a rock shield, having your coach in my garage would be a significant upgrade.
Hector
</IMG></IMG></IMG>
JIM & BARB'S bus garage.
Jim,
It looks very nice!
Question... How do you get the bus out? Looks like maybe you can drive it out the side door, but looks tight.
Dale, I back out into the teardrop drive and pull out.
The building is 38'x80' and the side door is only 12' high and one couldn't make the inside turn anyway. There is the remote possibility that I will put a door in the front one day to be able to pull out. I don't think so any time soon. I want things kept private from the street view, with activity towards the rear.
This was an existing building that I modified by adding the sliding door in the rear. I have added six 12'x12' rooms inside for stuff.
I have done all work by myself with the exception of the drive. Things are kind of hectic around here now, but I will post a pictorial story of my process as I get time.
This shows the drive from a slightly different angle.
Very nice bus barn Jim. Is that an additional bus storage area behind the left hand door?
Are you planning on joining the TBC soon? :)
Gary S.
