A footnote to all of Eric and Deb's problems. The original problem appears to be two leaky brand new air bags in a row. The old, presumably leak free air bag now installed will prove that as soon as this new problem can be corrected.
Just so everybody has the mental picture required, when the key (on almost all of our coaches) is "off" the air in all air bags should be locked in place by a five port valve that goes to its normally closed position. When the key is on, if the leveling switch is set to the road or driving position the path through that five port valve to the air bags goes through the ride height valve. In Eric and Debs case they have the bus fully raised so it is easier to work under the bus, and that ride height valve arm is in the position to exhaust air. Ordinarily it would not exhaust air with the key off, but in this case it appears the five port valve has decided to not fully close and is letting air pass through to the ride height valve which is exhausting air trying to get the bus to go down to the normal ride height. If the support stands were removed I suspect the bus would drop on that side until it reaches the normal ride height, at which point the ride height valve will stop exhausing air.
I know how much of a PITA this problem is by having worked for weeks to make my previous coach leak free. I also know how obsessive an owner can be when they realize how close they are to perfection and want to make that last little leak go away.
Here's the really scary part in all of this. Imagine if you will that this was happening on your bus. And unlike Deb and Eric you had no choice but to bring your bus to Prevost for air bag replacement. A slow leak in a new air bag would not show up as the leans for 12 to 24 hours. By then the bus is home leaning over in your driveway. So back you go, and if the techs do not fully understand the system some serious dollars will be spent by you until you either give up, or the problem is isolated and repaired. Doesn't that give you a warm toasty feeling?
