Yes, you can do it with solar, but...
Bruce, I've been living very comfortably with my 1100 watts of solar and haven't needed to run my generator (other than to exercise it) since January. However, 14 solar panels (8x100 + 6x50) are hard to justify if you're not fulltiming. Also, dedicating that much roof space to solar may require the use of :eek: basement air. My 24 volt 3-stage solar charge controller usually has my 8 8D glassmats in float mode by 10am and has my starting batteries up as well. I don't have my big 24 cu ft Jenn Air fridge running on 24v. yet, but spreadsheet calculations show I should not be forced to run the generator below 90 F. Summertime highs are usually around 80 F here in Flagstaff. With no sun, my generator charges all batteries through the inverter/charger.
In full sun, I've seen 40 amps @ 24v coming down. That won't handle your 220v cooktop or A/C and you must minimize your phantom loads, but you can nuke lunch and supper and run the computer or TV all evening.
My $.02 worth.
