Nother tid bit Even if your stuff is OK. I found a compressor in a Liberty a xl they put it in a box they build for sound and placed it behind the cruise air in that front compartment behind the bumper. Now it ran and worked. I was in there moving it to do things with the a/c and discovered that it had ran so long and hot that it melted its little plastic coolong impeller that is on the end of the motor shaft.
I rebuilt my aux pump last a year or two ago then it ran too long and the heat killed it so I ordered the biggest industrial 12v pump they made custom built the base about 6 to 8" longer and wired in a bilge blower fan right at the end of the motor fins so it kicks on and blows about 50mph wind across the air pump when running now it stays nice and cool I had to pat myself on the back for that one
Larry, I'm curious why a 12V compressor? My last plastic coach had a 12V compressor, which was far nosier than the cheap 110V unit I have in my Country Coach. We have so much inverter power available we really don't need a 12V compressor. Again, just curious,
If you want good capacity and QUIET, here's the real deal:
http://www.jun-air.com/product_detai...oductTypeID=50
There are always a few of them used on E-bay.
