You can get into any XL or XLV with just a putty knife.
My grandkids were playing with the switches near the coach door and apparently pushed the air lock switch. A little later I started the engine and went outside the coach, closing the door behind me. Shortly thereafter I tried to open the door and discovered the door airlock was set. Not problem, I had another set of keys. Well, the other set of keys did not include the keys for the engine doors. Breaking the window did cross my mind but I finally called a locksmith. He was unable to open the door where the 12v & 24v switches are located but was able to open the rear doors. Ultimately I was able to reach the switches with a long stick and recycle them to get my door open. Needless to say I now have extra keys outside the coach in case this happens again. :p
As for JDUB's comment on the toilet flapper valve. I never though of Saran Wrap! Last weekend a hand lotion bottle tumbled into the toilet breaking or dislocating the flapper valve. I placed some moistened TP over the hole to prevent the odor from entering the coach. Smart, I thought until we returned to the locked coach to discover warm temperatures had started the exhaust fan in the bathroom. This of course pulled fresh air in from the outside vent into the black water holding tank and out the toilet that had drying TP flapping in the wind. Nice odor, kinda like the old outdoor crap houses! Now if Jerry will just explain how to replace the toilet flapper I will put that on my agenda of things to do this weekend.:(
Well... Pulled into USA Coach service center in downtown San Francisco.
A guy came out with the biggest pair of Vice-Grips I've ever seen (Jon, it's on my list of tools to buy) and twisted part of the lock... Problem solved, no charge! Got a quick wash and we were off.
We pulled into the San Francisco RV Resort in Pacifica before 3:00 p.m.
Thanks again.
AJ
P.S. Is this what they mean when they say "expect a close neighbor?"
Darl,
If your toilet is a Microphor, you will have to remove the toilet to get to the flapper box in order to replace the flapper. Not a bad job, but I had the luxury of doing it at home in my garage. Here is what it looks like removed:
Attachment 1749
Looking inside from the bottom, the black box houses the flapper
Attachment 1750
Flapper with attached actuating arm
I am not sure of the brand name of this toilet Tom but I am sure they are all similar. If I am lucky it will just be a missing pin, etc. If not I will be ordering parts. I want to go to Twin Lakes by Bridgeport,CA for the last time this season for some German Brown fishing. If I don't get this fixed right away I might be using the JDUB Plastic Wrap trick! I sure appreciate your help and the fine pictures.
Gary, the way I have understood that issue, there is a pull ring on the side windows that you can pull the filler strip out and push the window out to get out. I have that on mine.
Come on now AJ, we don't won't to see pictures without the kids.:)
And, I'm thinking with the neighbor parked part way over on your site like that, well it think that permits you to idle for as long as you need to warm her up before heading out. Don't do it, but it sure would be tempting.
Great pictures and nice location. When I saw the proximity of the rigs I thought of the RV park in downtown San Francisco, Beverly Beach FL, a typical Liberty rally in Stuart......
