I'm impressed Gary. Low-tech confiugration with high-tech results! Great job.
I have looked at this post numerous times. Each time my amazement grows as to how applying simple techniques to get results. Being able to prune ideas such as these makes owning one of these huge machines much more manageable. This technique certainly goes along with my principal of Keeping It Simple!
Thanks for sharing.:D
Hector
Great Job Gary De. You really made it look easy. :)
I can hear everybodys mind whirling with their own ideas, of when they can use your idea in their own bus. :)
Gary S.
What inverter do you have in your bus?
Will it be easy to change the charge settings from the gel type to the new glass mat?
Gary, you indicated above that you bought GDL-8DA. I don't think that is a typo as the P and D are on opposite sides of the keyboard, what are the specs of the GDL-8DA, or should it have read GPL-8DA?
I am just lucky I guess, as my batteries are on a Joey bed. You just pull it out and lift the batteries up! You would think that some of these new and fancier coaches would have this wonderful feature!!!!!! They must have known that I have 0 mechanical ability and gave me a break.
Hi Jim. Heart 25 Inverter/chargers. Yes, it is GPL. The settings for the Lifeline are so close to what the Gel settings were, I left them as is. The Heart 25 is a 3 stage charger, and the requirements for charge were 13.5 to 14.4 volts which is within the specs for the lifeline.
Gary, my inverter settings are:
Left / no 1 Right / no 2
#1 off #1 off
#2 on #2 on
#3 on #3 on
#4 on #4 on
#5 on #5 on
#6 on #6 on
#7 off #7 off
#8 on #8 off
are yours the same?
About 2 months ago upon arriving here in Fl, I called Lifeline to see what the POG cost ov the 4ds would be and at that same time they informed me they had a price drop.
Enough of that, I found the closest place I could get the batteries was in Charlotte NC. shipping would be approx $150 or more and I would have to pay someone here several Lewbucks to put them in. I'm not beyond that, but the local rv mobile people don't even know what Lifeline is. Just the same, I have decided to pas thru Charlotte on the way home in May and have whomever they suggest put them in. I am seriously thinking og going from gel cell to AGM. I was told by Jon that if I had good service from the gel-cell to stay with them. I don't always do what I'm told, but if enough of you guys think the new owner would readily except either, well I may reconsider. (note: how I spelled reconsider, not reconcider) Here I go again, ADD setting in again.
Gary:
Nice! Just curious. Would an engine hoist work or is the boom too short?
Louie,
I think your better off with AGM's, even Lifeline says the charging cycles of AGM are about twice what you get with Gel and that means they will last longer.;)
