Please do not forget
it’s not the original engine
to my knowledge
3 air conditioning systems are in the bus
roof, driver and floor
to my knowledge
More pictures
I hope it is possible to get some idea now
I have to take a picture from the generator
he is hidden behind a removable wall
Parts of the coach are really professional done
Other parts not
after the builder / owner parted with the bus it was over with the proper care
the mileage is correct
under 6000 mls
it reflects the tires who still look like new
but from the stamp code are from 2005 all around
same with the provincial inspection sticker
2005
engine and engine department is not nice to look at
why ?
where is the problem to paint or at least clean the engine before you put it in ?
supposed to redone internally
sounds and drives like that
someone told me they changed the most stuff with the engine still in the frame
bottom line the engine does not match the expectations you see inside the coach
period
What runs off propane. Thats enough gas to power a cooktop for years. Water heater? Furnace? What? Although I am not of the opinion most of the prevo crowd view propane as a big negative.
I wonder how big the fresh water tank is it looks huge.
Regardless how much u turn up the hp in a bus when the coolent temp gets to 210 the ECM pulls the HP back and when u turn one up in a bus with the rad in the back that is what tends to happen so usually u can turn one up only so far and it will then benefit to some degree.
Attachment 17619
Attachment 17620
I told Cat to stay away from mine with the rattle cans. The absence of fresh paint displays the petina only a good piece with many miles can provide.
Eberspaecher heating
Fridge
Hot water
maybe more….
My best friend in Germany said the same
better to leave the engine like it is
looks honest nothing to hide
but it’s for sure no showpiece
Huge water pump. What toilet did he use?
That fridge will run for about a month on 1 20 lb tank.
Id like to see a closer picture of the paneltronics center in the coffee table. I want to see what all that is!!!
The panel is interesting
The generator has only 108 hours
does that fit to the mileage of 5500 mls ?
Paneltronics has a lot to choose from. Ive used that stuff before thats what ill use in mine. I like the look it kinda dates it but i like that era.
Attachment 17640
Attachment 17641
Attachment 17642
Attachment 17643
Here is an old project i did with paneltronics. Analog gauges and manual switch. Fun project. I like the way they format and organize the panels. DC volts and amps on the panel and AC volts and amps to the left. Between just the 2 sources Granger and Paneltronic i put everyrhing togeather. They r both still in buisness too!!
Attachment 17644
Attachment 17646
Attachment 17647
Attachment 17645
I built the box out of wood and got the shape and dimention exactly how i wanted.
