I used to think I was wrong, but then I found out I was mistaken
Quote:
Originally Posted by
dalej
If I were you guys I would invest in floor-dri, the way I'm using it it's bound to go up. I can't believe how much 90 weight gear oil soaks up this stuff.
Dale: You mean how much Floor-Dri soaks up the 90 weight gear oil, RIGHT?
Its probably just dislexia, or is it aixelsid. I think it comes with age. :rolleyes:
I used to think I was wrong, but then I found out I was mistaken. :eek:
Gary S
Some pictures is worth a thousand words
dalej
Jon, thats the tag axle and its easy to access the springs. The drive is hard to access. I got them off, just thought there might be a trick to easying the spring back on.
Post that picture Dale so the brain trust can postulate till Joe steps in!:D :D
Show all the parts ready to go in. ;) JIM
Bleeding the brakes on the Harley
Dale, Just wanted to be a smart a_ _. I am guessing you are filling your differential with oil. Ken
