Up until around 94 the only axles that have an emergency brake r the drives. 2 good opperating chambers r safe. If u loose preformance on 1 of the 2 Id be real careful about setting the emergency brakes and walking away with a toad hooked on ANY SLOPE. It might hold it, it might not. If the 1 remaining hub lets say has some oiled up pads from a leaky seal u will be off to the races. Be carful take no chances with chassis that only have emergency brakes on the drives.
2 Attachment(s)
Item 3. 1983 Chassis Restoration
Brake Relays
Attachment 15804
Attachment 15805
The end of 83 and the beginning of 84 thats when the width of the bus went from 96 in to a full 8ft.
Just as significant a milepost as the 99 to 2000 model year changes were when the XL Became the XLII
Many other elements changed too. The brake relays r 1 of those other things. The pre 84, 96in buses used R6 relays NOT R12. Its kind of tough to decipher from these photos especially if u dont know what your looking at but these r not r12 and r quite the oddity.
Im sure of whats here and unaltered and heres why. Another difference is the 96 wides pre 84s have ALL copper plumbing not easy to put anthing other than perfect replacements and thats what im looking at. Prevo Elgin also verifyed it was built with r6.
Prevo parts doesnt make too many mistakes but the associate verifyed no availability for an original R6 and erroniously shipped us 3 R12s telling us they would work. NOT. Not only would it require major surgery to replumb it because of the copper but more importantly the crack pressures r different r6 r12 and it would alter the dynamics and preformance. In their defence Ive never encountered an r 6 on a semi tractor, dollies and trailers, old ones maybe. Either did a good friend with a similar background OR the guy at fleetpride that has never been asked for 1 in over 20yr.
Im going to eventually talk to tech at bendex and find out what im told.
We found new old stock on ebay for 25 bucks a piece. I havent actually pulled these out yet. That will only happen when placed in my hand in a couple days. There r 2 in the back. The front one became really accessable once ive pulled the tires, and shock, and airbag, and hub, and the maxi now its a piece of cake. lol. i can reach right in there. Very nice.
It would be neglegant on my part to go this deep and leave these in there. This is a job that if a shop was asked to pull this 1 part and nothig else would be a royal pain in the ass task. The back one is entirely more accessable by pulling the base of the bed and removing the engine hatch. Chad tells me hes had it out before its not 15min of time. Ill swab and blast all that down too when I do.
The R6.......learn somethin new every chassis.
This wonderful 83 chassis.......Im the best thing thats happened to this bus since Liberty rolled it out the door 37 years ago.
5 Attachment(s)
Item 4
Brake Hoses
Attachment 15806
This is a Parker Hose. It has a swivel it is 1/2 in and its a made to length 1 time use throw away. Most chassis now have these.
Attachment 15807
Attachment 15809
Attachment 15808
Many earlier chassis all the way up to 2000 or so were endowed with Aeroquip 2 Piece swivel ends on the chamber end and a brass 2 piece non swivel on the end that screws into the relay.
This 83 came with a full set over the years it has been stripped of 3 of them for the lessor brand. Either someone took them and reused them or worse yet they ended up in the garbage. That aeroquip 1/2 by1/2 swivel with adaptor is 70 or 75 bucks. The other brass end is more reasonable.
These r great hose ends they r forever unless u destroy it trying to remove and disassemble it.
If your chassis has these dont let some scoostama remove them. For 5 or 6 dollars for the hose and 2 bucks for the brass ring and a few minuites it is totally rebuildable. With a few feet of spare and a couple compression rings u can redo a damaged hose yourself or at lease have the right stuff when the road service shows up.
Most All the air hose on the bus Is plastic or in the case of this 83 brass. This always takes preferance. Its stronger and lasts longer than rubber.
However if u have movement between the 2 ends of a line plastic will crack it has to be rubber in these spots.
Well there is a TOTAL of 8 rubber hoses on the chassis in 84 and 2020 remains the same 8.
This is the logic behind the design.
When its time to replace the rubber brake hose the throw away parker hose can for rhe same money be replaced with the reusable ends, the brass 2 piece on both ends. Going forward to the next decade and next replacement the cost is reduced significantly.
Attachment 15810
Theres 6 rubber hoses on the back and 2 up front for everybody. Heres the maxi waiting with all its drive hub related buddies waiting to team back up.
New, return springs, new rollers, new inner seal and gasket, new axle wedges, new tapered brake drum screws and complete drain of drive axle for 5 fresh gal synthetic oil.
The wheel bearings and races were all very good. The S cam seals and bushings were quite free while showing very little play all the alack adjusters were fine. All 37yr old stuff and still functioning as designed. Thats good juju to let these pieces roll.
Joe, you're a busy guy. I'll buy you lunch :-)
BTW, I heard Prevost Parts has a dded a few bucks in their marketing budget for you to promote their parts. Was that a good rumor ;-)
Keep up the good work!
R U makin smoke?? Where r u? The forum always gets quiet just prior a rally. I sence lot a people movin around. Yall be carful and have fun. I need another couple years before my Pete is finished enough to bring out in public. Then we will run up some miles togeather.
I want to go find some UFOs that be a fun trip.
4 Attachment(s)
Item 5
Shocks and Shock Posts
Attachment 15811
Attachment 15812
Attachment 15813
All this hardware stuff on pre 84 r different. Same shocks but installation different. First the suds r bolts that go all the way thru the suspension carrage. They also have 2 opposing wedges . Another item is the bolts need collers to go into the shock eyelets. The collers serve a duel purpose and facilitate bottoming out the nut when u run them up. If the long bolts r allowed to loosen up any the wedges start grinding on the tapered seat and if u wollow out those seats thats going to create a lot of time getting straight again.
Going forward 84 and newer no collers, the post is the correct diamiter and the nut is a lock nut and only tighteded up till the shock bushing begins to buldge. They r often overtightened verses the older stuff that has it nessessary to be tight.
Also when changing this older stuff if after the shock is removed the bolt and wedges r froze in the hole free it all up dont just throw it all back togeather like that. Id say it would be a good thing to have some wedges and collers coming wirh the shocks when u order them.
Attachment 15814
There is 8 seporate pieces of hardware that make a shock post on s pre84. 2 posts per shock, 10 shocks on the bus so it takes 20 assemblies like this for the entire chassis!!
This is fantastic.
1) Can you also include a description of where you are locating your jack stands and the process you go through to get them to take weight, and then de-weight the suspension / wheels enough to get them off?
2) What is the torque for the wheel lugs?
3) Is most of this in the 1/2” ratchet range or do we need to get a good 3/4” set?
Fratto this thread is maybe 50% or so applicable to your 97 chassis. Right? OK
650 FT LBS is the wheel nut torque. the tag steer and outer duel nuts r 1&1/2in. The nuts for the inner duels require a special square nut socket.
U should have a set of 3/4 inch stuff. My resources r limited IGo to harbor frieght and get their Pittsburg Forge hand tools stuff Very very strong guarenteed fraction of the cost, good chineese stuff (it kills me to have to admit that but there u have it) I use many of there tools and very rough with them on a daily basis for your purposes they will be perfect.
2 Attachment(s)
Attachment 15816
The yellow stand is the body support point at the rear. ill gey a closer pic later, its raining. On your chassis there is a thickwalled piece of square stock going from left to right same spot. Place the body support stands there.
Attachment 15817
Once you get the weight off the axles and get the wheels off another set of 4 stands go under the suspension at the 4 rear hubs. It does not require a 20 ton jack to get the tires up when the weight has been taken away. Dont kill yourself oversizing. Go to level low all the way up L and R rear. place rear support stands. Dump all air L and R rear. Jack and remove tires and rims install suspension stands lower and remove jack.
Ill get a couple pics of the correct tools to most easily pull tires.
Did u get yer fan hub straight?
Billy if u r reading this could u please send me a picture of those stands u picked up. Also send a pic of that off brand torque multiplier. Thank u
This old girl is starting to shape up aint she!!!
5 Attachment(s)
Attachment 15818
Fratto u have stud piloted hubs and studs and rims. This Is NOT NOT NOT a stud in the photo above. It IS IS IS, the " inner duel nut"
Attachment 15819
Attachment 15820
it requires an insert for a 1,1/2 in socket OR that specific socket.
Attachment 15821
so first u put the inner rim on then the ninner nut goes on the stud. There r threads inside and outside of thos inner nuts.
Attachment 15822
Once the inner rim is on and nuts tight the outer rim goes up and the outer nuts thread onto the inner nuts.
Prevo used this old school stuff on the drives for a decade after the trucking industry went to the current hub piloted that only require 1 nut for duels. prevo used these a tic past 2002 or so. Even some of the chassis with drive axle disc brakes still have old style stud piloted components.
