Got it was not aware of the new roof airs. In return not all country coaches front rear zones r controlled by the roof air thermostats. There r others that have separate thermostats for front and rear interior zones on the older conversions. There r others that also include a webasto programable remote u set the time on and can run on timed sequence when leaving for a weekend or something or to preheat prior to start up ect on some newer conversions. I just did work on a Vogue and they chose to eliminate everything accept going into furnace mode in zone 1 and 4. PERIOD Nice. A furnace that turns on with 1 switch. Imagine that. Good job Mr Vogue but it would be nice to have it more up on the dash its up your left armpit where it is now.
Joe, the Webasto can't heat the domestic hot water and doesn't have basement heat off the Webasto in the Vogue? If so, how are they switched? As you know, that's why some coaches have multiple switches or controls for the Webasto. That's one of the pluses to an AquaHot over a Webasto. With an AquaHot, everything is in the box and easily controlled from the AC thermostat and AH control panel.
The engine loop is constant on along with the domestic water and the bay is signaled by a thermostat set about 40.
