At least if you drive a Prevost you should have a good ground plane - which refers to the mass of metal at the base of an antenna. Fiberglass roofs pose a special problem as you can see and are for the most part useless. A simple SWR meter will determine if your radio is matched to the antenna properly - you can have a CB shop check this for you or any ham operator would be happy to help. A 1:1 match on the meter is the desired reading - meaning most of the power the radio generates is being transmitted. But assuming your radios are legal it would be limited to 5 watts of power which is pretty ineffective with a compromise antenna which includes all RV antennas. In a campground or in a caravan they will do fine but passing each other will require a very fast conversation:p
Anyone capable of driving a Prevost is capable of getting a ham license. Then with experience and motivation you should be able to make daily contacts from the bus to nearly anywhere in the US. Don't misunderstand - it is not a telephone like conversation and not possible everyday due to weather both on earth and above the earth. The conversation will be to another ham operator so it pays to get your friends interested as well. It is true wireless communication and a real thrill - especially when someone from another continent answers your call. More information is available at www.arrl.org You will discover that the relationship between CB and amateur radio is like a pop up camper to a Prevost.
Wave
w5sk (all radio operators are known by their call sign)
