My last leak was from an antenna on the rear of my coach. The self leveling roof sealant is just the thing to re seal.
I don't know if this will work or not, but if you have access to an ultrasonic leak detector with the optional sound making device you can try this and tell the group if it actually works.
The booklet says you can put the electronic noise maker inside the coach and turn it on. Take the listening device up on the roof. Scan the wand over each and every joint etc. The theory is that the sound will travel through the leak and you will be able to hear it in your listening device.
If this actually works, it would allow you to identify the leak, even if it is far away from the place where you saw the water in the coach. Plus, it would keep you from having to risk being spotted with a leaf blower taped to the window, or whatever contraption it was I read about on the last page.
Good luck. Please post results if you try it!
Debbie Faires
I had an antenna leak and I tried that. It did not work. I did work in finding leaks around the door seal on my plane using that method so maybe the sound needs a straight path from the emitter to the receiver.
Since my roof seams and pentrations were minimal I determined where my leak was fairly easily by running water and seeing it start to drip at an antenna hole. I could have saved the trouble of looking merely by just going ahead and resealing all penetrations and seams using this:
http://www.campingworld.com/shopping...-sealant/21208
I masked everything off so I had nice straight lines, applied the sealant and pulled the masking tape while it was still wet, and in the last 4 years haven't had an issue with leaks. The sealant is self leveling and does not harden, but remains flexible. If you don't mask it looks sloppy, and if you do mask and wait until it dries the sealer will pull up.
Every leak I've had in the forward compartment has come from clearance lights. At least on CC, they seem to be prone to loosening up and leaking.
I have an ultrasonic unit if your in the area and want to try it.
Works good on cars. Found a leak in a friends sun roof that the dealer could not find.
Truk, make sure you put on your official Liberty Bling suit before you blow your bus. Man, first sheep and now this.
O.K. Back to air type leaks. What soap works best and what percentage mixture in a bottle will show the most bubbles ?
Dishwashing soap mixed with water will work, but this is what the pros use.
http://www.alliedsupply.com/store/ca...5A180641C46513
That is exactly what I was looking for. Thank you !
Jim, You should be able to get the Big Blue leak detector at any refrigeration supply.
