Dale, If you are replacing a Stemco two piece seal with a Scotseal or National one piece seal, be sure to remove the wear ring that is used as a sealing/wear surface on the spindle with the two piece seal that Stemco makes, you can pull the one piece seal up over the wear ring but this will ruin the new seal. On another note, if you overfill, the excess oil will usually leak out through the weep hole in the hub cap plug.
