Truk,
I am no electrician but if you want 50 amps, then a 50 amp breaker is your protection, not 60. # 6 wire is code in CA for 50 amps, I think and depending on the distance you might loose a little. You should have 50 amps on both legs as long as the electrician wired you into 220, if not find a new one!
