truk4u,
The brakes are not directly affected by a reduction of the aux air pressure. Since the coach normally uses the primary air system to apply air to the brake chambers. Our coaches have three air systems, Primary, Secondary and Auxiliary.The primary air system is isolated by a check valve from the sec air tank. So the primary air tank will not bleed down through the sec tank under normal conditions. Air can only travel from the sec tank to the Primary tank.
The aux air tank (system) is supplied by the sec air tank (system). They are tied together at the aux air cluster located under the drivers seat, lower compartment (XLV). That is how the aux system is supplied. I am using Prevost drawing #D140196 as a reference. I have spent considerable time with the pneumatic drawing trying to learn how the suspension system works. It is a very busy drawing, but has mucho information.
Since I am troubleshooting an air leak (imagine that) where my primary and secondary tanks leak down overnight, I have been studying these pneumatic drawing lately. (I have found several bad check valves in the air tanks and air dryer in my system.)
If you drain your secondary air tank and the primary air tank pressure drops, your 'double shuttle check valve' , which seperates the primary and secondary systems is leaking.
I can see another POG Rally seminar brewing concerning these different air systems. Jon, Dale are you guys listening. I can help with the multimedia presentation.
Hector
