Originally Posted by
Jon Wehrenberg
Bruce, in the upper RH corner of the display it should read "mode" when you are in performance mode. It shows nothing when you are in the default economy mode. I think this is reversed for Tuga's coach.
I wouldn't bet about adding 200 RPM. I think under the exact same pedal pressure it may do that, but I have found I can do a full power acceleration in my coach and wind out each gear to max RPMs something not even close to possible in economy mode.
When you are climbing a steep hill you want the engine wound as tight as possible for maximum HP. I manually downshift to prevent the transmission from upshifting if required.
