Looks good. Is that the new Vette or a new emblem for the DD? :eek: :D
What did you have to do to post, reduce the size a little more than specified?
Yes....it is under the size specified by a lot. The frustrating part is the original size is the same as all the pictures I was previously able to post and is less than 10% of the size my window says is allowable for jpg or jpeg photos.
A demo is a great idea, Dale!! I would appreciate your help and I'm sure others would. Sandy
Attachment 1677 Kids on ATVAttachment 1676 Parked @ Cabin in McCall
Attachment 1678 The side of the road in Nevada after losing Awning
Thsi took a little figuring out on how to re-size but I finally understood what Joe was saying. Thanks Joe.
Glad to see that you've got it figured out. For a while, I thought it was just me!!
I know that even at the lowest resolution on my camera, I still have to re-size smaller to get the picture to up-load.
Sure is a nice shade of red...... reminds me a bit of my old 1970 convertible....350/350, 4 speed, factory side pipes... ah, those were the days!
Glad you figured it out. Something has definitely changed, as I was able to post much larger images prior, AND the forum limits are set to a much higher size. But still, anything larger than 600 pixels doesn't work for me. I get the same "error" window.
What did you change to make it work?
I went in and dropped it to 90% of 640 X 480 which brought everything down below 600 despite the fact my window on attaching a picture shows a sixe of 6000 square is acceptable. Shame on me for assuming 640 X 480 is less size than 600 X 600 and that the allowable listed size of 6000 meant it, and finally for assuming since my pictures posted previously were 640 X 480 that the problem wasn't size.
Size does matter. (Had to throw that in)
The red is Victory Red off of this.....
As I posted in that previous thread, for whatever reason, anything larger that 600 pixels in either dimension will fail. Don't know why, as forum limits are set higher. It's more likely a web server setting, which hasn't been correctly setup. Uploads to a webserver, without special "tools" are dicey at best, and require careful setting of web service parameters, which probably didn't get fully transferred from previous server.Quote:
Size does matter
Now to me, it looks like you use your gator for a service truck!
