" you can't ride in my red wagon, wheels broken axels dragging, same song second verse, should get better but it could get worse"
What a bummer, the worse part is missing Jons presentation on leans and other subjects. Yah Yah I'm gonna miss seeing some of you other jokers too.
Harry,
Very sorry to hear about this. What a jinx! So, is this not repairable in a couple of days? So that you could still come, perhaps a day or two late?
Holy Crap Harry
Geez Harry! What a run of bad luck!! Hey, its not that far, why don't you get a room in town, and commute to the rally. Its not very far at all into town?
We don't want to miss you guys! :(
See Harry,
You should have kept the other bus as a backup.
Mike
Mango; At this point I don't want one bus much less two. The sympathy I got from Shirley amounted to " well you wanted to run with the big boys. "
Harry,
Sorry to hear of your trials and tribulations. Hopefully, all will turn out well in the end, and this episode will fade into a distant bad memory.
Keep the faith...
Pahrump
Thanks Paul I'm sure it will and thanks to all the well wishers that responded. We had our hearts set on the p rally. It could have been worse, there is a lot of nothing between Reno and Pahrump. Our problem developed 40 miles from the repair shop.
Harry that is terrible news.
So that others may learn from your mishap I would like to tell everyone about a company that will come out to you and cut off a burnt spindle and weld on a new one right on the side of the road without having to remove the axle housing or tow your vehicle.
They are called the axle doctors. Google this or www.axlesurgeons.com
Sad to hear that Harry.
I suspect as Tom said that when they changed the seal they di not tip the axle or refill the bearing area with fresh lube. The folks that did your seals owe you the cost of all repairs. If they did replace the lube (doubtful if the bearings were dry) then the other cause directly traceable to them is they overtightened the bearings.
We were looking forward to seeing you and Shirley.
