You are correct. They are intended to support the coach at its maximum raised height so you can safely get under it.
If you have not done so, when the coach is raised, a person can sit in the area where the wheels are and do any of the work necessary because there is plenty of height in there. There is little or nothing to work on between the axles under the bays.
