Originally Posted by
Jon Wehrenberg
Curious as to how that adds up to $5000, unless you give your checkbook and keys to someone and tell them to make it work.
If it is a 4X4 is it towable with the transfer case in neutral? If not I am not sure a driveshaft disconnect will do the job since both axles have the potential to drive the transmission. Is the plan if it cannot have the transfer case put in neutral to put it in 2 WD and disconnect the rear drive shaft?
As to the weight, if I had my druthers our tow vehicle would be as small and light as possible. We towed a 3600 lb Jeep for 200,000 miles and it was the right size to keep our length legal, it was big enough to take four adults, and light enough so hills were not an issue. The Hummer meets the above criteria except the weight is 6700 lbs. You know you are towing it going up a hill.
A tow vehicle is a mess after a trip, and the bigger it is the bigger pain in the butt it is to get it cleaned up. As states get hungry for revenues over length vehicles become targets, especially if you have a heavy foot. A heavy vehicle will impact your fuel mileage.
If you have to add a brake pacjage because of the weight, and a driveshaft disconnect to make it towable it is already getting to be a pain. What I liked most about the Jeep was it was light enough that brakes really weren't necessary (probably a good idea, but not necessary) and to tow it we just put the transfer case in neutral. The more you have to monkey with while hooking up the greater the probability you will have flat tires on the bottom, or some other such calamity.
