Speedometer/odometer failure
This happened on the way home the other day. I noticed the odometer was flashing 8.8.8.8.8.8. and then the mileage, but was not counting up. Later after I stopped at a dump station, the speedo Needle wasn't moving until after about five miles when it finally made it to my running speed, based on the tach and cruise control which were both functioning. I called Prevost and they said it sounded like the cpu in the VDO speedo head had failed. I can go with that but before I order a new speedo any other ideas? Does the speedo get it's signal from the transmission?
Thanks.
