Originally Posted by
michaeldterry
Ben - I'll get out to the bus in the next couple of evenings and check the status of the SMX panels and mid unit thermostat when I try to run all three units. I'll also heed Jon's suggestion to shoot the temps at the air supplies and the air returns with an IR thermometer to measure the temp delta between the two. I'll try to remember to take a few pictures of my set up to post here for more information, too. That brings up another idiosyncracy of my bus though - I have an SMX panel inconveniently mounted directly behind the driver's seat that controls the FWD CruisAir, an SMX panel mounted on the outside wall of the A/V cabinet in the rear salon (next to the curside window) that controls the AFT CruisAir unit, but there is no SMX panel for the MID unit - it is controlled by a more traditional lokking thermostat panel mounted on the wall behind the dinette table (just forward of the refrigerator). Normally, I turn on all the A/C breakers at the MDP and control the individual CruisAir units with the FWD, MID, & AFT A/C switches on the front dash panel. To get the one that is not working to work, I have to switch off one of the running units and then switch on the previously not working one, as only two at a time will run.
Referring back to my original posting - can you tell me 1) are the filters one the one accessible unit in the third bay for both the mid and aft units?, and 2) how do I access the filter for the forward unit that apparently mounted behind the front bumper?
Thanks for your help and guidance!
