Inverter Problem Maybe ??
Does anyone have any ideas what our problem may be? With all our breakers turned off we are pulling aprox 20 amps on Leg 2 of our Inverter regardless of incoming power source. Leg 1 goes down to zero. I have tried turning things on and off one at a time to no avail.
We are currently at a rally in LA and hooked up to 2 30 amp legs of power via a cheater box and can't run any acs on leg 2 as the amperage goes to 35 amps right away.
I have set the Inverters down to 30 amps each.
It even pulls the same amps with the generator on... or when hooked up to 50 amps.... so I know that the cheater box isn't the problem.
Any ideas would be appreciated..
Does anyone have a clue where the 20 amps with every breaker turned off might be coming from??
