Originally Posted by
antioch01
			I know I am a newbie, but I just had a similar issue with our Splendide. The door switch gets sticky and does not release. You can remove the door switch and lubricate with a penetrating lube and it will free up by sliding the plunger in and out. The rubber bladder seal can be removed next to the door latch by pulling out at the edges to remove from the groove around the door opening. There is a wire in the groove of the rubber that may come out, but easily reinstalled. The door switch can then be reached and removed by taking the two screws out.
