I have a Doran Tire Pressure Monitoring system that I used on my last motorhome and I would like to use it on the Marathon.
Has anyone ever used a Doran system on their coach and if so, how did it work? Did you need the antenna extension?
I also noticed that the sensor will not fit on the outside dual. The outside dual valve stems faces into the wheel hole which is too small for the sensor. Can I just rotate this stem around to face out?
Thanks,
Killeen
