Where can I find bulbs for the ceiling lights??
Thanks
Jamie
Thanks
Jamie
The halogen bulbs can be forund at: http://www.lightbulbemporium.com/satco_s1908_10t3_f.asp
If the bulbs are 12 volt, you can find the replacement halogen bulbs at any hardware store (Lowes, Home Depot, etc.) Mine are 20W, 12 volt which are the same as used in low voltage landscape lighting.
This only applies with 12 volt lighting of course....
Jamie,
I ordered the entire light from CC for just a little more than the cost of the bulbs. I know some of the other POG members did the same. This was before CC went out of business, so I am not sure what the price is now. In May 08, I paid $5.91 each for the entire light and cover.
Jamie, Drop down in wattage when you replace the bulbs. The original wattage is too strong and the covers become hot, overheat, warp and fall off when traveling down the road
Wallmart also sells the bulbs.
Anyone know if there is a replacement LED light for the halogen lights? I'd love to reduce the heat and power used by the halogen bulbs?
That's a great idea. The reduction in heat alone would be worth the effort.
Right. Plus, I'm guessing it might make a noticable difference in battery time when boondocking?
I ran across this in a search:
http://www.lc-led.com/ledhalogenlightbulbs.html
Not sure if it's a direct replacement, but may be. 8.5 to 17 volts?
I like the part that they are "cool to the touch" ...
