Do You Have two of These ?
Do you have (2) of these parts on your bus? P.N. 24057
http://picasaweb.google.com/gstevens...y=CRD0snY0wGU#
Well I didn't and I wanted them. What are they you ask? They are called "Lever Rear Fender, Locks" They lock the dual rear fender assemblies in an up postion, so you can work on the tires or wheels. You thought you just had to stand there and hold the fender up didn't you? :o :D
But now that I have a pair and the nuts bolts, silicone washers to install them, they don't fit! :mad: Maybe that is why they weren't on there in the first place, BUT I am not through trying to get them on my bus.
The reason my NEW Levers won't work is because I also have color matched fiberglass fender trim on my fenders, and because of the extra fiberglass I can't lift the fender up enough to latch on the pin that is inside. It binds against the ss above the wheel well.
I need about an 1 1/2" taken out of the middle of this unit. Who can do metal working like this to remake in the proper length the assembly I need?
Gary S.
